What could be the price for a bracket in 6mm alu ?
The problem is ordering Material. I know no shop in Switzerland which can send me for 30 sfr, 6 or 8 mm Aluminium. In Germany is possible but then i must drive to Germany which costs fuel. So the cost is nearly the same. If you can send me aluminium i can do it for the Half the price. Btw i can also cut Carbon Fiber. Or make Motor Brackets. A previous work of me…
motor brackets? I’m confused now what are they for and how looks it like if they were mounted?
Sorry motor holders… A bit tired from the Work.
Motor mounts you mean? Im still confused by looking at the picture
Any progress on this? Or did the conversation end at @Miniproto not being able to source material?
I need a pair of brackets as well, was wondering if maybe people are interested in a smaller bracket design that would reuse one of the existing screw holes in their board, something like this:
Or, still with drop-through support (requires cutting your deck a bit to make a hole there as well unless you have a Hummie like nose):
I didn’t get a order, i can make plates cheaper now since i also do cnc work for other customers. Which i can combine materials and cut costs.
I’d be very interested in buying some of your straight brackets! How can I contact you about this?
