there is no info on them?
They’re intended to be replacements for their production board. They’re local friends of mine that I do some testing for, so I’m building them into a custom travel board.
YESSSS! Sofu is gonna kick some ass in here.
I can’t wait to see how that drive/mount system would do.
im so excited:stuck_out_tongue_winking_eye:
You’re welcome @pixelsilva glad I was able to help. This was the exact filament I used. It seems to print a bit more firm than a lot of flexible filament. It prints amazingly though! And it’s very affordable.
PRILINE TPU-1KG 1.75 3D Printer Filament, Dimensional Accuracy +/- 0.03 mm, 1kg Spool, 1.75 mm, Black https://www.amazon.com/dp/B074DV9JMX/ref=cm_sw_r_cp_apa_i_6owNCbMBHC0VY
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/10465?u=riako
hoooooo yeah !!! Can’t wait to see your new build !? Right ? Tell me I’m right plz !!
Yep! though for testing purposes I’ll be putting them on my S3 for now until the other parts are ready…
@mishrasubhransu My first one awlready cracked this one is a free replacement from skateshred. I just don’t want to fiberglass it as it will ruin the look. Hopefully this one will remain uncracked. On What area of the deck have you experienced cracking?
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/10464?u=eboosted
Is this a 12s10p inside an eBoosted enclosure?
@mishrasubhransu PP filament? Yeah I have found the fenders experience really harsh vibration and like to break.
this is my pulley for boa wheels, of course the factory made it
Which factory? Do you have a link?
it’s local here in Indonesia, my design.
It’s just PETG. I was just showing the quality of the print.
If you make it thick enough it won’t ever brake, but it would also consume a hell lot of filament. So, I guess it’s just a matter of finding the sweet spot in between. I had to go through a few iterations to find the weak points and beef them up. It’s been pretty good so far. Also I brush on a thin layer of epoxy to smooth the parts out for painting. It also provides additional stiffness and strength.
Yes,eboosted Evo39DS enclosure. With the discharge bypass BMS, the enclosure becomes a large battery pack and the FOCBOX Unity is screwed to the deck side. Inside the enclosure, BMS and FOCBOX unity face each other. However, removing the enclosure separates the BMS from the FOCBOX unity and facilitates maintenance. The 7S cells column had to arrange 10P in a rectangle. Also, use a slightly thicker gasket to slightly increase the internal volume of the enclosure.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/10477?u=grozniy @moon bug I’m in love PS: don’t get jelly @DerelictRobot
