Okay thanks for the answer!
Can you please explain further how did you paint the letters and symbols on the deck? Looking dope.
Thanks.
I just printed the letters on thick paper, and then cut them out with a knife. Then I stuck it to the deck and spraypainted it. That was before i got access to a vinyl cutterâŚ
Totalt i orden bygget Hvad materiale er dine enclosures printet i ?
PLA holder fint med en gummikant
Looks really awesome! Not so much a fan of the boosted arrow copy but to each their own Great name as well!
awesome build. you still got the enclosure files?
The probably-more-than-1000km-update!
Alright, here we go!
This board is so perfect for me, and it just got a lot better! I finally found a way to charge my batteries, without having a BMS, and still being able to balance charge. I also added an antispark switch (courtesy of @goldenHusky) as well as a LED button! I never have to take off the enclosures any longer!
The way I charge my batteries is that, first of all, I upgraded my charger to a 10s charger. Second, I added a XT90 as well as a VGA port for charging. In the left picture the covers for hiding/blacking out the connectors are on.
This makes me able to use the same charger and system for both my boards! The cable itself is still in a âbetaâ phase, Iâm not exactly sure if Iâll keep it as a single cable or split it into two.
Iâm able to charge this board in about 1hr, and it goes more than 30km on a charge. Purrrfect.
She just got a wash today, so hereâs some more pics
i am a total newb. For your charging system, how do you charge with the batteries still connected to the esc? I use 2 5s batteries is series, and i have to disconnect them, to connect them to the charger because there is one xt60 plug on each.
Could we get an update on how itâs running? Anything youâd like to add?
i have the same doubt of @sid1 . i am running the same setup, 2 X 5s and how does it work this schema? thanks
@sid1 Sorry, I completely missed your question⌠I tried drawing it for you. //cc @xBRAZILx
@UniqueSnowflakeN27, It still runs like a baws, I even used it in the rain for a couple rides, and still works like a charm. I plan on upgrading the VESCâs to FOCBOXâes, and the motors to sensored, so I can get sensored FOC up and running. I also want to upgrade it to 12mm belts, since I break a lot of belts. I accelerate and brake intensely a lot.
Nice! Thanks for the update Have you thought about adding a fuse?
I had one on my earlier revisions, but since I got my new antispark switch with LED support, which doesnât have a fuse, I havenât really been âwantingâ it. I use the same argument as @goldenHusky, that I do not want the fuse to blow at the wrong moment.
Your Build looks premium
Maybe I missed it but what is the main charge port for? You should be able to charge solely on the balancer VGA port (or are you running âcrazyâ currents?)
thanks for your reply, and now i noob question haha
talking about the âmain charge portâ. do you have to put âa loop keyâ in order to power on/off the board? or the BT drawed in the second picture is the power of/on button?
I charge with 1C, which is 10A. This charges the board in 1 hour!
The extremely thin wire I used on the balancer cable wonât be able to handle that. I canât find a 11 pin cable that can handle that. (That looks reasonable, and doesnât cost a kidney) And 11 pin since I also use the same cable to charge my 10S board.
@xBRAZILx I plug the âmain charge portâ and the âbalancer portâ into my charger. The anti-spark turns my board on and off. I just leave it off when charging, but works either way.
