Hi all,
I’ve decided to make an eboard after a bit of reading and Youtubing.
I am planning on ending up with a duel belt driven board but due to cost I’m starting wit a single motor to start with.
So lets get down to it,
I have;
1 x Z-Flex long board deck with risers (to be modified when time allows.
In the mail;
1 x TURNIGY AERODRIVE SK3 - 6374-192KV
2 x 218mm Torque Board trucks
1 x new Torque Board motor mount in red
14 and 40 teath pulleys from Torque Boards 12mm
4 pack of 280mm belts from Torque Board
90mm red wheels with bearings of Ebay
Still to get/decide on;
FOCBOX - mainly because it looks reliable/easy/AUSSIE
10S5P battery, enclosure and charger from DIYeskate
Controller - can I get the meepo one without their other stuff?
Bluetooth for the VESC apps
Off road wheels to add riding options in the future
Thats it for now although I will upgrade to duel 6374s at some time in the future for torque and braking, I’m 115kg, but for now this qill do me I think.
Any improvements or stuff that will not work together?
Any help will be appreciated.
Dude it looks like a cool build the only thing I would say is maybe look at the Turnigy skateboard motor simply because it has sensors versus the Aero Drive, might be smoother
If the motor is already on the way, use that one unless it doesn’t fit. If you’re using a single motor it should fit and on the TB 218 trucks two of them should fit even but not on some other trucks
For the controller, you have a big decision to make. Do you want to control the throttle and brakes with your index finger or with your thumb? It’s personal preference.
To be hosest i could go with either and get use to it, and then probably feel weird with anything else.
I like the idea of having the three speed settings so I can cruise while sitting down with my four year old son ( only on quiet back streets.)
I would probably like to be able to start without pushing in some circumstances. What would you suggest that is not crazy priced if I had to go international?
I also use a 192kv SK3, and honestly it’s not a big deal having to slightly push to get going. You only need a very small push and then just apply throttle to taste. Esk8ing will feel pretty awkward to start with but just ride a lot and you’ll get used to it faster than you expect
EDIT: I’m 110kg and even a single SK3 on 6S is pretty fast. You’ll have no trouble on 10S
