Well planned setup, 16/36 will give you good speed with little less torque but since you don´t have hills in Florida, you won´t get any problems with that.
The only thing i would think about again is the choice of your batterys. I´m also using 2x 5S Lipos and seeing all these great flat 18650 li-ion builds here kind of pisses me off that i went for these big lipo blocks
Are your trucks Calibers? You also need Flywheels. You can go with the clones as well, but if you can swing the real deal, I’d stick with Abec11. My preference is 90mm to get you over any bumps and gravel.
I’m still new to this but I’m about to start a fairly similar build. You’re probably already aware but you’ll only be getting around 7000rpm with a 190kv motor using a 10s setup. You’d be able to maintain your desired top speed (~48kph?) but with a better reduction ratio giving more torque if you went to a 12s setup. This is all assuming an 83mm wheel.
Hey, I have a 5055 brushless outrunner, a skateboard, rc transmitter, esc, but I need a motor mount. I`ve tried before and failed, but I want to try again and make a easy to make motor mount or buy a cheap motor mount, any suggestions? Would really help me out.
My deck is a 42" Sector 9 board I’ve had for about 4 years. I love it. Super flexy, I know that’s not great for electric skateboards, I have a separate thread about that.
Ah nice if you do a boosted board style enclosure (batteries on one side of the board near front truck, esc and remote board near back truck) it could work with a very flexy board.
I think you’re asking for speed wobble with that setup. Flexy deck plus double-pivot rear truck is just too much instability at higher speeds. And I’m saying this as a guy rockin a sidewinder up front myself. My rear truck is zero degrees, the back wheels don’t turn at all. I can’t do figure-8’s in my driveway anymore but I’m much more stable at high speeds.
You live in the flats and you’re light. I agree with the poster above that you should look at hubs. Hit up @LEVer, he’ll set you up with a single-hub rear truck and a vesc. His hubs are basically the same motor as the one you want to buy, but it’s rewired for more torque than his last version. You won’t have to deal with any brackets, pulleys or belts and it’ll coast more like a skateboard.
