A build thread! Hold on to your penis - this is going to detailed
This build is becoming quite popular/generic now and that’s because it’s damn beautiful. I’ve had a lot of questions about the pictures I’ve put up so here’s a build thread so that we can all own this amazing gathering of talent.
I had a lot of fun with this, I started ordering parts around August last year… esk8 cares not for your time constraints
First things first, choose a theme for your build:
Shopping list:
Deck: @Hummie single channel
Enclosure: @bigben single stack enclosure secured with m5 inserts and bolts with fender washers. I stole this enclosure straight out of Ben’s workshop before he had even had time to finish it properly I had to resort to child labour.
Mounts: A set of Psychotiller TKP mounts
Trucks: Surf Rodz 177mm TKP trucks back and front. Front axles 80mm and back axles 90mm
Wheels: Using Torqueboards TB110, ABEC 107 and Bergmeister wheels from Haggy @riverside.rider depending on where I’m riding
Battery: 10s5p 30Q pack built by a master with a small bestech bypass bms. It needs to be flexible because the deck is bouncy.
ESC: Focbox Unity, I made little adapters so that I didn’t void the warranty and because I know it would piss Brian off.
Motors: Maytech unsealed 6374 x 2
Pulleys: 3DServisas push fit pulleys for urethane, Bergmeister pulley for pneumatic and steel motor gears from @JLabs. 15/40 and 15/60.
Belts: 285mm x 15mm continental belts for urethane. 350mm x 15mm for pneumatics. Top tip: don’t buy cheap belts.
Bushings: Riptide Krank Tall Barrel 93a board side and Riptide Krank Fatcone 93a road side from @Alphamail
Grip: Jessup grip tape - but I’ll use vicious next time because when I’m riding on the promenade and sea sand gets on the deck I lose grip on my feet and I can’t do sick 180 dick flips to woo the ladies.
Miscellaneous buys that add up to 7 million dolla
For axles I use 80mm M8 shoulder bolts on the front and 90mm on the back (with push fit pulleys on both the bergs and thane)
I keep my wheels, spacers and bearings together on the axle with the bolt through them all and spacers and shims in place with a m8 nut on the end for storage so it can’t all come apart. That way I can swap from thane to bergs in less than a minute and pop the other wheels away on the shelf, in my bag or simply hand them to my man-servant.
For spacers I just found a local place that sells 10mm ID 16mm OD allu spacers, they can be had online though for very little. Get 10mm long ones for most of the spacing at the back but some 30mm ones for your front axles are great because you only need one of them on each side.
To shim you’ll need washers. 10mm ID 13mm OD 1mm thick like these - https://www.ebay.co.uk/itm/Aluminium-Flat-Washers-6mm-8mm-10mm-12mm-14mm-16mm-18mm-20mm-22mm-26mm/281770185167?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 - Get shitloads of these!
Weather strip was used as a gasket and I used 2mm thick sheet foam inside the enclosure to reduce vibrations and keep everything tidy.
Bearings are these https://www.ebay.co.uk/itm/10x22x6-Rubber-Sealed-Bearing-6900-2RS-10-Units-/142101569350 - There’s nothing better and they won’t break the bank.
There’s a grub screw in the hangar, take it out and throw it away. Vibrations from longer axles will cause it to scratch and mar the surface of the shoulder bolt and you won’t be able to get it out after ~100 miles. A bit of 290 loctite on the shoulder screw is all you need to keep the bolt in place.
Loctite everything! After about 20 miles I took everything apart to look at it (thanks for the tip @akhlut) and my bearing seat to hangar bolts were both backed out to the point where they were ruined and the thread was questionable. 290 on everything you might need to get out and 680 on your pulleys.
I chose not to drill any holes in my enclosure, taking a leaf out of @bigben’s book.I wanted to keep water ingress points to a minimum and not mount anything to to enclosure so that taking it off and working on it would be easy. Charge port is mounted on the side of the board and I roll to start with my unity, battery meter is my phone and I plan to extort one of @b264’s plug in meters from him as soon as I get some juicy ammunition.
Shoutouts to all the people who made the stuff I’m using, @mmaner for all the advice and useful threads, @Sender for his abs of steel and @DerelictRobot because no one else loves him.
Build images in no particular order, just a random collection. Trying belts, wheels, testing fitments and spacers.
And finally, here she is in all her glory:
