Torque Curves for SK3's || 6354 260KV || 6374 149KV || 6374 192KV ||
Hi Everyone,
As some of you may know, I am doing a GB (groupbuy) for SK3 motors, mostly customized with keyways and sensors so people don’t have to mess with those moddings. I was able to get some Dyno Testings from the manufacturer, which I myself was looking for a few months ago on the forums. To no avail, I asked the manufacturer and they send me some very nice graphs for the dyno testings.
Enjoy. 6374 149KV
6374 192KV
6354 260KV
Wow, thank you! I’ve looked all over for these
So did I :sunglasses:
I noticed they are all tested at 38V. Do you know if they have similar charts for 12S, specifically the 6374 149kV? I believe it would just scale the RPM line, but I’m curious if the efficiency would increase
Either way, these are great. Thanks again
They asked what my specific personal battery pack was so I told them 9s, (sorry) but I probably should have asked bigger packs since majority of users have big packs.
Very nice! I wonder what their dyno looks like!
And also someone in a Facebook group pointed it that at the bottom it says 5025/5045, those are just factory part numbers.
looks like stator size. actually more accurate than can size…:nerd:
That could be it.
Do you think you can get this motor on the GB? And some data… not sure if it’s the same factory
Ive been curious about it for a while! It has double the poles. Kv is perfect for 8s-10s
That’s not a good motor if you want to use it together with a VESC. Because the ERPM would go as high as 120000. And that is by far above the recommended max of 60000.
+1 for 12s data. Can you request that? Probably 46-47 volts - fully charged with some voltage drop.
Really interesting information.
Motors are running at 80% efficiency at full load. Motors are putting out 2-3hp after efficiency losses! Running clockwise is slightly more efficient, but not significant.
[quote=“wmj259, post:1, topic:19721, full:true”]
Enjoy. 6374 149KV
[/quote]
@wmj259
It is interesting to see a value above 6000 RPM. At 38V and 149kV, you would think the max speed would be ~5600 RPM
So perhaps a motor’s kV is a function of nominal speed under load, not an unloaded maximum speed. If you look at the max and min of the purple line above, 5600 RPM is right in the middle
Side note: Did you ever hear back from the company regarding charts for 12S?
Used my mad powerpoint skills to add a RPM line for 12S
Approximation for SK3-6374 149kV @ 12S
I haven’t had a reply about that topic. I will ask again, but I think they used motors from my order to perform these. I will check again.
Even if they had charts of any motor at two different voltages, we could see if/how the voltage affects other parameters
I’m researching for my own build and am actually desperate for this info for my own build!
Are there really no speed-torque curves for motors at different voltages?
These look like great datapoints but i’m at a loss how to use them.
I have the 6374-149, and I want to run it at 1000rpm. It doesn’t look good for me.
I need a ton of torque, it’s for a marine motor and i have option of many propellers. I want to get 2hp if I can, but how do I determine torque and current at 1000rpm? This dyno appears to be running flat out, and then ratcheting up a brake until the current meets a limit right?
This would suggest with 99% duty cycle if I overload the motor with heaps of prop torque at 1000rpm I’ll just cause a very high current (beyond the 55A shown here, extrapolated? A short circuit I guess? Am I right in saying I don’t get the full 2hp until I let it run up >5000rpm?
Thanks for the help.
There is no way you are going to be able to pull anywhere close to 2hp at only 1000 motor rpms. You will need to use gearing to reduce the motor speed to your desired output speed. In general BLDC motors are most efficient at about 80% maximum rpm. Your motor is going to wildly inefficient at 1000rpm with very little torque output
Great, thanks.
I might need to rethink things and go for a planetary reduction. fun. Or bigger batteries.
what about the guys making wheel hubs, surely they go very slowly and they’re direct drive on resonably high kv motors? they’d be doing low rpm right? would they have the same issues?
