Problem:
After setting up my board I went to test it and found that under load (standing on the board) the motor jitters and has trouble starting. When not under load it spins just fine.
My Equipment:
Torque ESC BLDC (Link)
Torque Motor 6355 190KV (Link)
12s2p Battery Pack (Link)
Steps I’ve taken:
Upgraded the VESC firmware.
Ran through the motor setup wizard successfully.
Ran through the input wizard successfully.
Parameters in VESC tool
BLDC Mode
Motor Current Max: 80A
Motor Current Max Brake: -60A
Absolute Max Current: 100A
Battery Current Max: 50A
Battery Current Max Regen: -10A
Max ERPM: 100,000
Max ERPM Reverse: -100,000
ERPM Limit Start: 80%
D 0.20
I 3.00A
w 5000 RPM
P 0.00 degrees
IB 3.00 A
HB 3.00 A
I’ve read other threads on here and tried some of the suggestions. Nothing thus far has helped. This morning I did change one parameter that seemed to help quite a bit, but wasn’t sure it’s the RIGHT thing to change.
On the General Menu, Advanced Tab I changed Minimum Duty Cycle from 0.5% to 2.0% which seems to have made a difference (at least with bench testing, haven’t ridden yet).
, who is the vendor gave me the battery max value of 50A for that pack.
I can get the board started and yes kick starting will get it going but after reading others using similar components you should not have to do that when it’s setup correctly.
What battery do you have? Link points to the esc.
Batt max most probably set too high.
Jitter sounds like sensor wire is not connected/bad connection, or hall sensor mode not enabled in vesc, or sensor detection not set up, or hall sensors are doa…?
Besides the fact that your battery max can output 40a I wouldn‘t run 50a on a hw4.12 vesc without heatsink. Just my suggestion. I know they write 50a on the homepage
Andy87 - Thanks! I ran it with out the first several times, but this last time I ran it with - So, I do need to go back and remove the belt and run again.
Also, thanks for the suggestion on the max erpm. I had no idea what to set this number to.
Yes, I have applied the result of the motor wizard after it ran. I know many people forget that, but I did do that.
I am running in BLDC mode so the sensor wire is not connected. BLDC vs FOC is new to me but when I talked to diyelectricskateboard support he said that I should run in BLDC with out the sensor wire (in fact he said it won’t work with the sensor wire connected).
Ok, I’ll drop the max down to 40A and see how it works. I don’t think that’s affecting my jitter issue but it may save my ESC. What should the absolute max current be set to??
Just let the absolute how it is. Looks good.
Without sensors it’s normal that it jidders.
Like @Sebike said, give your board a small push and it should run without problems
People run bldc mode with sensors. I don’t know why the TB support guy told you otherwise. I don’t like stutter, so I’d run with sensors if I were you.
With a 12s2p 30q batt max should be 15 to maximum 20 a per p pack = 30 to 40 for the battery. Has nothing to do with your motor issues though.
