MY PARTS FOR THE BUILD:
1.Modular 10s4p batteries with printed enclosures.
Each battery is 86WH - The whole total amount of wh after joining them togheter is 420WH. The batteries that were used is LG HG2. Each pack has 8 cells.
2. For the drive I will be using CARVON 2.5 SINGLE HUB. I expect the range to be around 25MILES.
3. VESC - AXLE VESC.
4. JET SPUD - For the deck I want to use 34.5 JET POTATO.
5. ENCLOSURE And now the worst part …ENCLOSURE …I need to find enclosure that can fit around 38mm-40mm of height because the last battery pack is pretty huge due to the LED button that I am using. I pray to god that maybe @psychotiller could help here with some of his great enclosures.
