Hello. I have a problem with a very weak brake. The film shows that the brake is very weak.
I suspect that you need to set something in the software just do not know which option suits it.
Honestly… I dont know what else to recommend… U can always make a different gearing for your board - for more power for example, Ive heard this also helps but im not 100% sure…
On a side note - sometimes it is better to have weaker brake, than a too strong one
can you make a video how you test the brake and how good or bad it is now?
you can tune the brakes on that ESC very strong! I have used that ESC and had it braking so hard it stops the board dead and you street your face!
you just need to change the settings with the program card.
have you changed the brake rate switch point setting???
