I’ve been thinking of adding underboard lighting to my board for a while but never saw a solution I liked.
I then came across the Chroma LED driver which was designed for racing quads, but works a treat on my board.
It’s limited to controlling 25 sequential LEDs, but can run up to 50 so I ran two lots of 25 in parallel.
The Chroma has everything built in, I bought it from the site below. I had to buy a 6S to 12V voltage regulator as wasn’t sure if the Chroma could take such a high voltage.
I then bought a 60 LED 1M WS2812B strip from Ebay which i cut into 2 x 25 LED strips.
I cant seem to find the Chroma LED Controller in the US. Does anyone no of an addressable WS2812B LED controller that has multiple modes & colors, that is available in the US? I really dont know anything about these LED’s but I’ve been wanting to do this for awhile now.
right, but is the regulator hooked up straight to the XT90 (or whatever connector) coming off the battery pack, or did you use a splitter and then another splitter (if using a dual motor)?
@jimbosays I have a wire coming off the XT60s connector going to the above voltage regulator, with the positive going through a switch. This was an additional wire tagged on the outside of the connector, the inside was taken up by the lower guage wiring to the ESC.
Here it is in action. The fimware seems to have an issue with two LEDs not lighting up in pulse mode, works perfect is all other modes. I’ve let them know so hopefully this gets fixed in future.
