Had to drill the plates for the countersunk truck screws (all 6 holes are the same now)
On the positive side of things got some Bronsons G3.
Did fuck up the drilling the ABEC core. Wheel pulley installed uncentered and only 3 screws got in.
I did want to assemble the firefly, but decided to go with the plug-and-play solution.
Does nanox so much worse than gt2b? Or is it just slightly better?
The Nano X just doesn’t have a high quality feel to it, which a nicely modded GT2B does. Connection with both is rock solid.
Nano X is very jerky on a high power board. GT2B gives you a lot more travel so it gives you more precise control.
Does nanoX feel like evolve gt r1 remote? If yes then I glad I ordered the nanox
I got kinda bored after got r2 evolve. Yes, the acceleration is smooth but it doesnt feel like that wild beast with r1
What happened with the wheel pulley? Didn’t understand.
Originally bolts didnt want to do through, so I drilled the core with the 6mm drill bit. Did first wheel just fine, but on the second wheel I drilled few holes at a slight angle. This caused some missalignments and now pulley isnt centered and rest of the bolts cant be screwed into the pulley. Will fix it tomorrow
Update:
Fixed the wheel more or less. Drilled for 20 minutes (this abec type core is tough one.) Managed to get all screws in and good enough centering on the wheel pulley.
Received Focboxes, connectors and remote from eskating.eu
Seems like i will need to do some soldering
Did order orangatangs 80mm since i’ve always wanted those orange beasts
P.S. afaik battery is done. @koralle and @rok are waiting for bms and ready to ship the battery, enclocure, charger. So 8-12 days and some assembly later I’ll be able to ride this beast!
Did consider caguamas, but 68$ wheels + 40$ of shipping from US or 100 eur shipped from netherlands. FeelsRussianMan
Did order 80mm ones for 68$ shipped
Now all the BLDC tool magic has to come in, but I scared even to plug the USB into the FOCBOX.
Might figure out the low voltage power delivery for motor detection.
But still dont know if i should plug everything and then configure or preconfig and then CAN bus the thing.
