hello all i am trying to update my vesc to v2.3 i am at v1.14 now. when i open the new version of the bldc tool for windows and connect i get this message
so i go to the firmware tab and in the update new firm ware section i hit the choose button and this pops up
i tried opening all of these but could not get any firmware updates. how can i update the firmware on the vesc using the windows version of the bldc tool?
i haven’t figured it out. i still need to try a few things but what you have done is probably what i am going to try. it hasn’t been high on my priority due to the snow. i might be able to try tomorrow. Merry Christmas everyone!
Quote By: Benjamin Vedder. Using the wrong firmware will most likely kill the FETs and/or the drv, so when you change firmware you should use some kind of power supply that cannot deliver too much current at first and preferably a low voltage (<20 V).
Only attempt to change the firmware if you are aware of the risks. A failed firmware upgrade can permanently damage the VESC. The enertion warranty doesn’t cover faults relating to failed firmware upgrades.
With the VESC, we usually don’t recommend trying to update and change the firmware unless you know exactly what you are doing. It isn’t too terribly difficult, but if you were to incorrectly update it, your VESC very well could be dead.
Are you asking what windows version is compatible with FOC 2.8, or which VESC PCB is compatible?
well i tried upgrading firmware again today and ran into some issues.i first tried updating on the newest version of the bldc tool but it could not update due to the older firmware on my vescs. next i tried downloading the firmware from that bldc tool using an older version. it starts by saying buffer erase under the loading bar but it then switches to buffer erase timeout, and doesn’t do anything. any suggestions on how i go about fixing this?
Hello locktight…just wanted to know if you managed to fix the upgrading firmware issue? I have exactly the same problem with my version 4.12 VESC trying to upgrade from 2.15 to 2.17 - 2.18 issue and I have no idea what to do. Cheers, Alex
so im doing my first build for learning purposes but im in this situation i got my 4.12 VESC with firmware 2.18 and i got the windows BLDC-Tool ACKMANIAC mod 2,53 and it says the connected vesc has too old of a firmware… should i get an older bldc tool or update the firmware of my VESC. and where do i get the firmware or the tool cuz the older tool i got is the 2.52 from ackamniac would really appreciate the help PS: i got my vesc motor receiver and controller all hooked up and the vesc is powering the motor and i can control it with the remote so at least i got the remote pairing thing right i guess any help would be deeply appreciated
