Hey folks, I wanted to build myself a vedder anti spark switch to save some money. So i decided to buy a few more of the components which i will sell. Please keep in mind that i am selling a KIT not a finished product!
Vedder anti spark switch github
The kit i am offering includes the following components: R1, R2, C1, D2, Q1, Q2, PCB, 3x soft switches and 2x fuses (40A / 58V) http://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/optimized/3X/6/7/6788abc41e4d606599fc8aa5d3885c0d1d8c9710_1_666x500.jpgTo build a switch yourself you will need this kit + soldering skills (smd soldering for the mosfets) + wires + plugs. I assume you will have everything to build one yourself.
The result would looks like this:
You can use another switch than the given one! You can use any Rocker Switch. E.G. you could use such a LED push switch:
Attention:
There are different ways to illuminate the switch when powering the board. E.G. use a BEC attached after the vedder switch to illuminate the softswitch. But if you do not want an external power supply you can buy an “illuminated rocker switch”. Generally they are not as nice looking as the normal led push button but it will work out of the box!
Wiring push button:
Normally there are 5 pins: C, NC, NO, +, -
Ignore + and -. These are for the LED only.
I am offering this KIT for 25€ + shipping.
I am located in germany but DHL says on their site that it does not matter in which country i will send them, the price will always be the same: 3,70€ + 2,50€ insurance/tracking.
Somebody else has not the possibilty to solder the two MOSFETS on the PCB. Without an smd solder it is actually hard… So i will offer to solder the mosfets on the PCB for additional 3€ that you only need to solder the other components (which can be made with a normal solder iron)
If you buy more than one kit the shipping cost will be the same because the components are not big and will fit in a letter no matter how much.
NON EU-Customers: If you want me to declare the package with a lower price (because of custom fees) the insurance will just cover the lower declared price in case of loosing the parcel on the way…
If you have interest just write a nice PM
