Featuring all terrain capable long travel suspension, 4WD, and plenty of power; long travel independent suspension with over 6" of travel; aluminum alloy parimeter frame, traction control four wheel drive.
Up to 18 miles per charge
Top speed up to 30mph
Up to 35% gradient hill on fast mode
Maple-Composite construction
Deck lenght 48 inches
Shock absorbers with nitrogen charged coil over with adjustable preload
Frame with high strength TIG welded aluminum alloy with a titanium powder coat finish
10" inch off-road tires
48v Lithium Ion battery with custom battery management system
Regenerative braking
Light weight rechargeable 2.4 Ghz multi-channel remote with cruise control
Four high output sensored motors
Two and four wheel drive select-able drive settings
Four models to chose: SX-5 Sleek, SK-5 Stealth, XC-6 Sleek and XC-6 Stealth
I knew that looked like Florida. Too bad it’s too far for me to go check them out. Maybe @longhairedboy can, the website says they are located in saint Augustine.
How’s the maintaince? From what I heard in Vegas, with the Baja board, you spend more time adjusting and tuning. It than you spend riding it. Seems like the more complex you make it, the more maintaince I would expect.
I like seeing an evolution of this concept. Hub motors = heavy unsprung weight. Absolutely a big disadvantage when offroading… Would like a closer look to their suspension/steering as bumpsteer is really tough to engineer out and very crucial to stability. The Baja can barely be ridden flat and smooth at 20mph, Would like to see how these guys made 30 with 6" of travel. Video looks like a good time but would like to see it in a race at a bmx track heads up againsed conventional AT wisdom.. If this thing will really do 30mph on a 35%grade you guys should bring it to the Barrett Junction Esk8 uphill race in January. Would be glad to have you and see this in action…
I think they will @MoeStooge …if they were members of this forum! It was my idea to bring attention to this company, but 'am not related to them and I don’t know who they are. Sorry guys.
The panel of peers in this forum are the world’s Esk8 judge, jury, and executioners. There is no other place like here with all of you. Sorting out the good and the bad is just a part of progress.
