Yes, I did everything according to the instructions.
The motors spin when the gas is pressed. But if I press the motor with my hand and press the gas, it does not spin, that is, my strength is greater than the effort given by the VESC.
You have to push start uncensored motors to get them going.
Edit: Your motors are uncensored so they don’t know what way to spin So you need to push them in the right direction for them to start, so there’s no surprise that it dont spin, and please don’t screw with your vesc settings LOL.
Everything is fine, What I’m trying to say is your motor does not have sensors It will not Start powerfully on its own hence why Your hand can hold it down. Do you still not Understand?
All I can say is When using Vesc and uncensored motors. you have to give it a small kick to get it going. Some people like a smooth start not 100% gas wheels up So Startup boost is for own preference and If your board rides OK don’t worry about the wheel not spinning when you grip the motor It’s normal.
Nice But be careful with Vesc settings If the Vesc pulls more amps that It can handle It could blow! So after changing this setting the board does not even start after a small push?
