Then around how much
I more meant the quality of the deck. Then most people would pay around 50-100 for a vinyl that they pick design, color, and where the vinyl is (the price I noted is not including a custom deck)
k thanks and for a custom deck without the decks price just for customisation how muchā¦
What dose that include? Just a blank deck with a large vinyl sticker? Are you sealing the vinyl and adding grip? if so how?
Just vinyl sticker sealed down onto the deck
Then how does one add grip?
Either just hexagons of griptape or vinyl on underside of deck
I donāt see the vinyl holding up like that very well. And the underside of my decks are typically 90% enclosure if possible.
How would you do any sort of custom board then
The only way is to do small squares or hexagons of griptape
Agreed 10cha
It would be sweet to see that glass frit used in some art work to transfer to the deck tho
How was this one done
Glass frit is the answer to custom decks butā¦ epoxy and vinyl donāt work great together.
The epoxy really needs to soak into the wood. Theres a few spots on mine that didnāt seal into the wood so i have air pockets that will probably break at some point. Cloth is better.
I donāt really get how glass frit works
Can someone explain
I thought epoxy would be easier and better
Wait wait wait! You sure are asking a lot of questions for someone that is looking for a friendā¦ Seems fishy bruv
Its epoxy with bits of broken glass tossed in as it hardens. You can use different grades of glass as well as different colors. You can hardly see mine because its clear glass.
If I could draw I would have been doing this long ago believe me the 90% I am getting is no where near enough
Can you send a link to where I can get it and how to apply
