So I finally got my board up after months of work, and after riding for about a week (25 miles?) I’m now having an issue where my VESC-X restarts on full acceleration. If I accelerate more slowly then it does fine. It hasn’t shown this issue until all of a sudden. I’ve included my settings. I’ve seen setting the “Max input voltage” to 57V is that recommended? Is that the Motor Max setting (just to be sure)?
I’m terrified I’ve killed my battery.
Motor max/min - 60A/-60A
Battery max/min - 30A/-12A
Absolute Max - 130A
What battery are you using? Liion Lipo? Max Discharge? There have also been cases of bad Vesc x that have cut off due to low voltage from a bad resistor or something along those lines, and you may want to double check with the seller who sold you it
You didn’t write the config for it. You have to do detection to get the values, hit “apply” or write the fields in manually, then hit “write config” to write it to the VESC
