Top Speed - 40-45 km/hr
Range - 40km
Weight - around 10kg
6000 Watts of power from 2 motors that are belt driven
0-40km/hr in 3.5 seconds in “Track Mode”
PCB’s are custom-designed. Internals will be completely unique, not cheap chinese components.
All components integrated into the deck. Deck will have a wooden finish (bamboo most likely). To a bystander, it will look like a normal longboard.
Traction control through an electronic differential.
Sleek and ergonomic controller with an OLED screen.
What are your thoughts? Any suggestions, comments and criticism is appreciated!
(i know it seems like we’re all flaming you here but we’re not i promise. It’s “consecutive criticism” You need to do some reading. and from that you will learn how to achieve your desired goals. We’re not a crowd of bullies I promise )
Or, you could do the reading we suggested and find builds simular to your build and compare and contrast. Like it was already said, you’re really not doing anything new that hasn’t already been done before. Unless you make it hover. Then we can talk
