My packs are “bring your own enclosure” which most are i expect.
If you’re looking for an all in one universal battery in a case with room for other stuff you may have missed the boat on the Space Cell Pro, an enertion product that led to the current enertion sled which isn’t a DIY available solution really unless you’re a pro builder and can find a way to cleverly extract a couple from them through some kind of deal or proposal.
The DIY community needs something like this again. I will definitely have something eventually but its too early for me yet. I still haven’t found a reliable direct supplier of 30Q cells for a reasonable price per cell at 1000+ unit quantities. then probably a couple years from now the 30Q will be the 25R and somethig else will be the 30Q and we’ll have to start over. I’ve heard about them, but the hunt takes resources i can’t fully deploiy at the moment because of my workload. The quotes i’m getting are still stupid. But when i do, and when i finally get my new nickel bus plates made, it will happen.
Somebody step up. I don’t have time, i’m too busy building the craziest fucking boards people can think of.
There’s definitely a gap in the market for this now,as there are people that want plug and play and don’t want to be drilling/cutting there enclosure themselves.
@12meterkuk you might be better off looking in the used section for a spacecell pro battery or put out a wanted post.
I’ve been using @willpark16 batteries with @psychotiller enclosures and they’re great. He even came up with a custom solution for a 12s4p where the cells are stacked so it’s less than 20" in length
We (Rocket Boards) have invested in a resistance soldering iron and will be offering some high performance 30t battery packs with a custom made bms specifically made for the VESC, usb ports, lighted power switch, small charge port, and in an enclosure, in the near future.
I’m debating on making my own via soldering (I don’t have a spot welder) or getting some prices on here for some 12s1p packs for the inboard m1. If you make batteries shoot me a pm with a price and details.
Edit. Looking for spot welded with bms. I’ve priced this out to build it myself it will cost about 100 bucks
Yea I’d say a bit more than 100 you need a charger, led, discharge port, more than likely an antispark switch and nickel strip, spotweld welding will cost more but if you can’t solder properly you will damage cells
i am developing a antispark switch that would be controlled directly by my remote also by a pushbutton, with added functions to control brake lights as soon as you hit brakes
I’ve been working with lipos in large scale rc for many many years now. I can solder better than most. I build custom high end racing drones as a little side biz.
making them myself isn’t an issue. I have chargers capable of powering a 12s pack but can only balance up to 8s so hense why I need the bms board as well. Just curious for prices. I’ve done my homework. I’ve built and repaired many a Lipo pack so these cells will be a breeze compared to actual lipos.
