yeh sorry new around here, @accrobrandon sorry about the link in your thread i thought it was an info thread and saw others post chargers there too. removed post. apologise about that.
what thread do you have for charger and does it have AU plug? im also looking at doing a 7p build so the higher amp is what im looking for
go to aliexpressā¦ theyre reliableā¦ if you buy bigger than an 8amp you might have a larger than normal charger depending which u buyā¦ 8 is pretty solid tho
No biggieā¦ That dude on mine was trying to be a smart ass like āwhy should I buy yours when thereās the same for cheaperā ā¦ Except he didnt even link the same comparable chargerā¦ Basically didnt do his homework before trying to punk me
yea Iām that smart ass, sorry to have offended but your egregious price seemed to warrant a response.
if I needed a charger Iād get this one, 8amps, adjustable voltage to 60v so works with 10s or 12s
MYSWEETY Adjustable DC Power Voltage Converter AC 110V-220V to DC 0-60V Module 60V 8A Switching Power Supply Digital Display 480W Voltage Regulator Transformer Built in Cooling Fan
No offense I got the 8a charger that @accrobrandon sold and I didnāt find it expensive itās something I can Chuck in my back pack and not worry about it, canāt do that with the charger you linked it seems more delicate.
Iām not mad atchu u shouldve just linked this one first and not one that didnāt fit the statement u were trying to makeā¦ People have options and some have particular levels of ādisposable incomeā and although a particular item maybe cheaper or even a better performer it could just be something fits a particular look theyre looking forā¦ Whetevers good
Is this a constant current / constant voltage power supply?
Btwā¦ 0% charge for liions is 2,5 v, but not recommended to discharge that low, so people usually donāt discharge till no more than 2,8-3,0 volts.
Do you sell charger with AU plug, I donāt want any, adapters. Or if it just takes the standard PC plug I can just use 1 from here since they are only like $4 but I also need to know what charging pins it has so I can get the same. Iām after a GX16-3 pin or even 2 pin specifically.
no, just order one off aliexpress and you can specify what plugs you need in your orderā¦ AU plug and 2.1 or 2.5ā¦ or whatever it is u wantā¦
Idk where you heard that but it does charge all the way to 50.4V. That is the voltage that comes out. It works great and it hasnāt had any issues. The case is plastic but having a fan on it is a nice touch.
Who know this charger Is good or not ? Thank you
I use a 3 amp 12s charger from miamielectricboards. Itās a 12s7p 30q pack. 40$
3amp is gonna take like 10 hours to charge a 7p. He should use a more powerful charger.
i got sum arriving tomorrowā¦ ill tell you what i think after the weekendā¦ #reasontoride =P
So if a pack is 8p and you are using an 8a charger, is it effectively like charging each individual cell at 1a? This should be fine for battery life right? Or am i missing something?
Yes you are right!
But you will have to use something else than standard 5.5x2.1mm charging port, they are rated only up to 5amp
Thanks. I have absolutely 0 electronic knowledge except what I have read on this forum so Im glad I am slowly getting it
