What charging plug are you used one your board
Hi guys What charge port on your board are you using The XLR AC jack 5.5 2.1 mm … And if you have a link it will be the best thank you
I use the 2.1mm jack
What charge you have
Thank you
Luna cycle charger for 36v
I have 50.4 v I don’t know if the jack will work for me
I don’t know if the jack will work for me I have changer 50.4v
Look up what jacks can handle your voltage
I look and all the jack is 30v
I look but all jack is The rated load: 5A DC30V
Do you have the link for this one Thank you
This is what I used…
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F322396791153
No I don’t you should be fine with the colts as you need to be careful about how many amps it can handle
The one a look The rated load: 5A DC30V My charger is 4A 50.4 I have 12s battery Do you think it will work or no Thank you
You should be able to find a 12s charger. Just look google 12s battery charger.
I have the charge The think I whant to know is If I take this jack If it will work with the charger want I plus it and nothing burn
What charger are you using Charger for 12s 50.4v 4A
This on i want to used With a charger 4A 50.4 v Is a charger for 12s
C300 body chargers…
What battery you have
The 54.6v kind
