With the added friction from the extra set of wheels, along with your board now having to accommodate a towing capacity, you’re much better off simply carrying them in a backpack. Maybe to account for the added weight, use a backpack with a waist strap.
not sure why the trailer here’s necessary, just put it in the center of the deck in between your feet…
similar to bara’s extended backpack battery, i made a small extended pack in a pelican 1200 that i can parallel to any of my boards. i can just set it in the center of the deck and you’ve got instant +560wh boost.
I feel like it would be a haste to go over bumps and the added cost of the other board 4 more wheels and some kind of connecting solution is just not practical.
My reason to use a setup like this would be;
Esk8 only for day to day commuting, and the trailer for long runs to visit places out of town (a friend or parents). This way the aesthetics of the board wont be ruined by a pelican case between your feet.
I tried this and I can tell you a few things by looking at this
First, the trailer has too many wheels and will instantly wipe-out. It can only have back wheels. Also, use steel bushings in that truck LoL.
Second, you have to put the battery under the deck or it will immediately flip over unless your hinge mechanism prevents that, in which case it’s jerking and pulling your back truck and trying to wipe-out the front board.
So you have to use huge wheels and the center of mass needs to be under the wheel axle. And only use two wheels in the back that don’t steer.
The trailer I made, I took apart again because it wasn’t practical.
