Evolve AT set - used for cca 500km. In one wheel there is a little bit bigger inner tire, something like 200x50. but it works perfectly normal. 90 eur
Evolve Super Carve trucks - used, some wear is visible, but nothing too bad. comes with 3 RipTide pivot cups, all original orange bushings, original motor mounts and covers - 90 eur - SOLD
Cheap ass chinese AT - brand new, comes with two 50T pulleys and two 60T pulleys. they won’t work with evolve super carve trucks, because axle has to be at least 45mm. 90 eur - SOLD
Haggyboard Bergmeister - brand new, I will include 3d printed pulleys of your choice. You can choose original one from Haggyboard website or @Riako’s for tb218. I am personally using Riako’s pulleys and they are really good. 160 eur - SOLD
Evolve F1 107mm - used for less than 100km. in pretty good condition. 110 eur - SOLD
3d printed pulleys with SKF bearings that fit on abec core and evolve 10mm axle. bearings are without any screws, they are press fit on evolve setup. 8 eur per piece, 15 eur for both.
Meepo V1 hubs - hubs with non-replaceable urethane. In good condition, a little bit rusty hanger. Comes with purple nipples bushings. - 50 eur - SOLD
Meepo front trucks with 90mm black wheels - in good condition, with purple nipples bushings - 20 eur - SOLD
Meepo front trucks and wheels + hubs + purple nipples bushings = 60 eur. - SOLD
Hobbywing ownboard esc with remote - used for less than 50 km. very smooth esc. Comes with 3d printed case with same hole placement as meepo/ownboard/wowgo esc case. 55 eur - SOLD
Loaded Tesseract - in very good shape, edges on the bottom side are sanded a little bit from previous owner - 100 eur
Meepo V1 batteries - one is without bms (physically there is bms, but it burned out, so it was bypassed.) other battery with charge only bms. I have probably around 30 cycles on each battery. cells are something like samsung 20p, not quite good cells. voltage sag is noticeable. good batteries for cheap build. without bms - 25 eur, with bms 35 eur.
2x KEDA 6364 190kv motors 2kW - each motor is brand new, still in box. 35 eur per motor. both for 65e!
more info: https://hobbyking.com/en_us/kd-53-30-high-voltage-brushless-outrunner-190kv.html
bestech 12s bms 80A - in NON-working condition - I think something went wrong when I charged battery with unplugged balance connector. There are no visible burn marks on bms, and it always gives around 7V output. 10 eur
Gullwing Sidewinder II - only one truck, just arm was used a little bit, base plate and hanger new. Comes with stock bushings which are not in photo - 15 eur
2x Nano remote with 1 receiver - I could not bind old remote with receiver anymore. Receiver flashes light, but nothing. Then I got only new remote, and I still can’t bind them. I’m selling this set as faulty, but who knows, maybe I’m just bad at binding? 20 eur
nickel strip - 12mm wide, 0.2mm thick. corrosion tested and it is real nickel. 3 eur/meter
SQ8-S connector - 150A cont, 200A burst. with anti spark. new. 7 eur for a pair
2x aluminium 20T pulleys for 15mm belt with 10mm bore - 8 eur for both
2x steel 18T pulleys for 12mm belt with 10mm bore - 10 eur for both
5.5mm bullet connector - 2 eur for 3 pairs
fishpaper - 23x23cm sheet - 2 eur
amass xt60 - 1 eur for a pair
amass xt90-s anti spark - 3 eur for a pair
LED waterproof push button - Green for 10s, blue for 12s - 3 eur each, button and wires
battery % display - 10s and 12s - 5 eur each
battery insulation rings - free with any order
5.5x2.1 charger socket - free with any order
RipTide washers - free with any order
JST 2mm 5 pin and 6 pin cables, male and female - free with any order
JST 2 pin connector - free with any order
samsung 30Q battery - brand new cells, from Nkon eu - 4 eur for cell
12S battery with bestech 80A bms with e-switch - I will build you a battery! I like building batteries and I have spare bms for one more battery. I know I have no battery building reputation here, so my price will be quite cheap and I will post all photos of battery building process in this thread as proof of methods I will use. I will use 0.2mm x 12mm nickel strip (maybe few layers, depends on cells layout), fishpaper between series, insulation rings and connections between series groups will almost always be made with 2 silicone wires. on photos you can see stuff that I will need in battery building process except jst connectors, kapton tape,foam and hot glue. price is 70 eur for bms + 4.80 eur per cell. for example, if you want 12s4p, that will be 70 + 4 * 4.80 = 300.40 eur. on/off switch and charging port included. I can add LED on/off switch for 3 eur and battery % display for 5 eur. - not enough batteries left! order if you are ready to wait two weeks for shipment of new batteries from nkon
I am offering 3d printing service for cheap with any of your order. I have abs, petg and nylon, but I still have to master nylon.
shipping inside EU is from 10 to 20 eur with tracking, depending on weight of package.
paypal preferred
