No problem man I was also worried
Ouch man, that sucks. I’m borrowing a board right now and put it on an auto off timer whenever charging thanks to your story.
My TB DD came in… and my deck got routed and @Sender prolly gonna skin it cause i dont trust it right now…
calculated top speed is 55mph (unweighted)
Good job on the milling!
edges were not as sharp as i would have liked them to be… it was also my first time using a router
It matters not, I think you did really well
Are those 110s?
Yep
#&84erwh
Chunky ain’t they
If you are getting a bigger deck to match, I’ll take the Hummie off you
no thanks
See? My prediction came true you got your drives when you got your deck routed
Alright.
Bump, might cancel the build as I cannot find a enclosure…
Also traded in my TB DD 90Kv for 2nd batch 75KV
My budget is drained and I’ve tried once before but failed and I don’t have a pump.
I’m paying $200 to @Sender and then only have around 100$ left, which won’t get me anywhere
Maybe you can find a diy fourm to help you figure out how to make one
Idk why it replied to wrong person…
Will a psychotiller bigley not work?
Hummm… Have you ever done paper mache? Lol
It’s actually similar to how you can make a fiberglass one. Its a mess but its really not that hard.
Yes lol actually
As silly as it sounds. when you go “outside of the box” of decks with available enclosures, figuring out an enclosure for a deck can be one of the hardest parts of a build.
I’ve done quite a bit of Automotive fiberglass. Maybe I should get back into it and make customs.
What happend to the custom one being made?
