15/32 2.13:1 ratio
i thought it would have been more like 72 on the big all terrain wheels
ah, the AT wheels are 66T
ok so if i were to use some mbs wheels the evolve at belt
the pulley i should use is 66t pr 72 tooth?Whatever would fit in your wheel. I’d suggest buying belts from a 3rd party and use a center distance designer such as this one https://sdp-si.com/eStore/CenterDistanceDesigner. It’s much cheaper to buy them factory direct.
i am in Australia i just couldn’t acess the au website know anyplace for australia
That’s a 3mm pitch which won’t work with the default 15T motor pulley on the GT if that’s what you’re asking. You should start your own build thread and ask questions there since we’re getting a bit off topic.
i can just get a 3m pitch pulley. i will be using parts from my first build so i will check what the pitch there is i think it is 16 tooth so it would be 60/16 3.75
Back in action Also got a killer bushing set up now – will post in the bushing thread. I can do full blast GT mode no problem. Already wanting more power…may swap down to 90mm wheels
97mm are the fastest lol.
I’m loving 8in ATs but have hit overheat cutoff a coupla times.( starts after 2mins ).
Pretty much go 40/41kmh on flat ground on both setups.
Finally spent some quality time with 8in ATs, 2 hours 19 miles top speed 24.9mph but only on fast setting flat pavement, not GT. Saved GT for torquing through the offroad, 8in AT are awesome and went over anything NYC had to offer.
Where did you get your 8in ATs?
Purchsed different color AT wheel hubs (camo & pink) from evolve.au but the 8" AT tires (green, yellow, black) are still offered on evolveusa. https://evolveskateboardsusa.com/collections/wheels/products/mbs-13035-t3-knobby-tire . These 8" Knobby tires fit on stock evolve AT wheels (the MBS wheels do not work, larger bearings etc) and stock 7" evolve inner tubes https://evolveskateboardsusa.com/collections/wheels/products/7-inner-tube. Everything works fine, but have to take off AT belt covers to use 8" knobby wheels. Definitely worth trying, and get going fast.
that’s what i do at the YMCA
Yes McBurney YMCA, Union Square NYC!
Is it true that it takes at least an hour to change from street to AT wheel set up. A tad misleading from Evolve adv. id expect 15min reasonable time to change all wheels, but am I too unrealistic.
Good to have the option, but its not just a plug and play like fhey make it out to be.
Takes me 15 minutes
Yes 10-15 minutes
