Parts needed:
AMS1117 3.3v voltage regulator
22uF and 0.1uF capacitors
3x4 proto board
I find it easy to cut from larger piece with regular scissors going through the adjacent hole line, then trim
Put 3 blobs of solder in the third line
Align the reg and solder the legs. This should be easy due to the prepared blobs
Insert the 22uF cap through the holes. Note the ground leg. Then solder the positive leg to the middle hole.
Insert the smaller cap through holes (you should have two legs in the leftmost hole - ground)
Solder the legs to the board
Snip the legs short and solder to the regulator
Add wires: two (black) to the ground leg and one red to each of the remaining legs
Black+center red go to the mini board. Black + right go to the output from charger board
Everything is looking good so far. Any tips for soldering to the pre existing legs on the pre built regulator? I’ve never soldered to something like that before.it appeared you used shrink wrap.
Cool just wanted to make sure there wasn’t a more technical way to do it. I wouldn’t mind it being on all the time but you can see it glowing thru the case so gotta get rid of it.
