It has hardware issue running 12s FOC during hard acceleration and braking, but no problem at 10s FOC. I guess you have shown that it also doesn’t work at 11S.
Mm how is the accelerstiob with those hubs with flipsky esc?? I am thinking to make the same setup.
Only 10s.
How is the torque,top speed, battery consumption???
Go 10s or try bigger capacitors. Bigger caps have not been proven yet but it would not surprise me that that would solve it.
The current caps look tiny.
i am guessing the smaller size of the vesc took its toll on overall performance. But you can also read people having faults with other vesc at 12s foc. I would rather play with gearing/hubs than change my battery to a higher S.
I didn’t really ever expect this esc to run 12s foc. I can’t be the only one. You wouldn’t really expect a HK sk8 to run it, hell people even dispute focboxes should do it even though it’s been proven a thousand times that they can.
I noticed this…both their dual 4.20 and single 6.6 use the same 220μF 100V caps. People have been saying good things about the 6.6, while the 4.20 has cutout issues. Why is this? @Kug3lis any explanations?
They’re same on my dual or FSESC4.20 and FSESC6.6
I heard that caps. will be changed on next 4.20 …
Kugelis or Pimousse already advise me to change them on my 4.20s…
For same as 4.12 maybe ? (on the right of the pic)
Also seeing many people trying they’re 4.20 under FOCk without issue… Maybe I will give it a try too
got over current and over intensity on 10s bldc … I ride during fiew days all good under 20A motor and batt max, then I got faults during downhill braking…
I will make more test with higher batt max see if it change the game …
some test here
Edit
1st ride : 40A motor max and min / 30A batt max -15 batt min
2nd : 30A // 25A batt max
3th and good but not that powerful : 20A batt and motor max
I made more change 5Amps by 5A itch time, I change setting with Metr.Pro, I just let you know on the main lines
Have you tried setting it below 30a I remember some people have cut outs with maytech vescs when they were set higher than 30a. I can’t remember if that was batt or motor though
