From doing a little bit of research and also getting the VESC6 version, the JST connector changes depending on hardware. VESC4 uses a 7pin UART connection where the VESC6 uses an 8pin.
I modified my VESC6 connecter by shaving away some of the plastic and rearranging the pins and it works flawlessly.
I would say try the VESC4 version, otherwise the PPM adapter that came with your UNITY will make it work regardless.
The benefit of UART is that you don’t really have to calibrate the remote inputs, it all should be plug and play for the most part. You just have to set settings on your UI accordingly.
It got to the point where I don’t even connect to my unity with the unity app as I worry it might change my settings or fuck it up in some way. Connection losses, some stuff not saving like custom cut off voltages. Frequent recalibrations cause you stop for a beer and after you turn your board back on the motors are jerking. It’s all just software, some bugs have been fixed over time but many remain. Though it’s just literally patience issue. I use metr module for unity and the METR app and everything is fine The main thing is unity won’t turn off or let you down, it won’t throw you into a ditch like Evolve. Dealing with things that just take patience is something I can deal with. Even though I sometimes bitch about Enertion, I love their products (except for their remote:)
hi we are the 04/10 and i don’t have tracking for my ORDER #27332 of 10/07 …What’s happen please . I have send tickets , and you never send respons. @Deodand
I also checked the resistors and measured them with my multimeter (cause i first thought it were fuses). If i measure the one with the red circle my multimeter beeps but if i measure the other ones (blue) it doesn’t beep. Which ones should i replace? They are 0,001ohm which is less than the minimum my multimeter can measure.
Anyone knows what caused the burn and broke my board? I contacted Enertion last week and marked it “Critical” but they don’t seem to take customer support seriously. Still haven’t got an answer.
@Jinra is there a problem with me being factually correct that Jeff and many others are giving more rapid and helpful info on another website? If you dont want me or others to mention that specific website you can just make a thread about it instead of flagging, editing, and deleting posts.
I did remove one post with that guy text spamming a repair agent, but only because his phone number was exposed. The OP reposted it with the number censored and that one i let stay.
