If you want a weak performing board, stick with the 30Q, it’ll do fine for you. But if you actually want to increase performance and the life cycle of your cells, the 30T is better.
I’m ignoring cost aspects, so I know that will come up.
Lets add up the costs of these packs.
Lets assume the 30Q cell is $3 per cell and the 30T cell is $7 per cell.
The 12s16p 30Q pack costs $597.
The 12s4p 30T pack costs $336.
So performance for your buck here, the 30T is cheaper.
Now we look at my second example, which is more practical.
The 12s6p 30Q pack costs $216.
The 12s3p 30T pack costs $252.
So in this case, performance for your buck, the 30Q is cheaper, but not by that much…
Now yes, again, I’m ignoring range. Lets assume at these higher amp draws, the 30Q dies at 2.65 Ah and 30T dies at 3 Ah (As the graph I posted above).
12s16p 30Q is 42.4 consumable Ah.
12s4p 30T is 12 consumable Ah.
And the second example.
12s6p 30Q is 15.9 consumable Ah.
12s3p 30T is 9 consumable Ah.
So yes, if your after range with these high amp ratings, the 30Q yields better results. But these larger 30Q packs need more space and take up more weight than the equivalent amp rated 30T pack to get this range.
If you want high performance with long lasting cells and range, the 12s5p or 12s6p of the 30T pack will be the winner. Long range, high amp rating, and a longer life cycle.
