Hi Guys,
Bit of context, about 2-3 years ago I tried to build an electric skateboard, bought all the parts, drew the diagrams, aaaand as you can guess it failed. pretty badly. If I recall correctly I shorted the BMS (connected the batteries in the wrong order -> saw smoke -> BMS showed no resistance anymore, I think that means its dead right? if not thatd be great). Since then the project sorta lost momentum and its been laying in my closet. Not wanting to live with that kind of failure, I recently booted up the project. Unfortunately, it seems like my tech is a bit outdated, and I really dont want to repeat the same mistakes. I’d appreciate help of any kind, ESPECIALLY with the electric diagrams and compatibility (more on that below).
Here’s what I have:
Batteries: 12s LiPo
VESCs: FocBoxes (if I recall correctly)
RC: enertions remote
Motors:
Drivetrain:
Board + enclosures:
Power switch:
Cursed BMS:
(ignore the duct tape and stuff)If someone could whip up a circuit diagram, I’d be super grateful (mine were pretty bad). Also, any tips on where to find another 12s BMS that works with this build (supports charging and everything), would be really great, back then I was lucky enough to join a group buy, but I dont know exactly what I’m looking for.
Finally, apart from the BMS, another problem I had was that none of the parts could connect with the pins and connectors they came with. The controller receiver had 3x3 pins, and the vesc had no such input. the motors and the vescs wires also didn’t fit. I assume I’m not the first person with these issues but they seem so obvious that no one made a post about it (that I could find. those i could suggested mtm servo cables but none of the were 3xx3 and the one i have doesnt fit the focboxes. ).
Ive invested a lot of time and money, and I really want to see the project rolling (sorry), but I am woefully inadequate (18 years old, no engineering degree or anything), so if someone with more experience can help me out, that would be wonderful.
I figured this would be a good place to post, debating if I should make a new thread…
Any and all replies welcome
Thank You!
