Awesome I am stoked It’s all in a all I need to perfect my build
I’m making an enclosure for a Moonhine Sidekick, if this doesnt work that one might also work for your kicktail deck
What do you use to mould your enclosures?
Or
And
Length dependent…
And for a bit of class, curtisy @Deckoz…
Pick your color to match your theme!
Do you know where to get the cable ruber gasket ?
No I don’t. I am using regular weather seal and cutting a channel in it for cables. I have some rubber sheat I might use thoug instead… Then after everything is all good, I will through a dab of silicone where that cable gap is… thats just my plan though, take it for what it’s worth… pennies on the dollar
Think what he means is “wire grommets”
Focbox uses 3/16ID wire grommets for phases
10AWG superworm pass through power cables I use for loop keys are 5/16ID wire grommets
Yes i would like to buy some
Just search for the ID(inner diameter size) and “wire grommets”
Ex: “3/16ID wire grommets”
Pico 6116PT Vinyl Wire Grommets ID 3/16" x OD 5/16" 50 per Package https://www.amazon.com/dp/B0002ZG3RM/ref=cm_sw_r_cp_apa_i_Ty26Ab7D4EGGV
Thanks I just ordered a pack hehe
Hello guys, I just finished the enclosure, I’m pretty happy with the result because it looks pretty damn good and the lines go along with the shape of the deck.
There are channels for the ESC wires, for a professional look:
There is enough room for a 10S4P but a 10S3P would leave you a lot of room
Hope you guys like it.
Amazing… Now leme get my paws on it lol.
Love it. I’m ready to buy, especially if you can bundle it with the Spud deck with JLabs
How much thicker do you think the double stack will be?
15mm more than this one
Wow… That looks 100x better than my current spud enclosure… Good work!!
Dude you are a good among man lol this is amazing. Next the double stack can’t waite
Nice now how can i get one
Totally awesome
that bundle is going to sell out quick az fuuu sorry jin meant to respond to page not u specifically… its 5am
