After some Customers needet to modify my standart pulleys this ones should fit directly.
Removed the Hub, added a 3mm Keyway and a Setscrew inside the flanges.
But as on some other Motors the Motorshaft itself has to be shorten do 27mm.
30€ more for the Dual Drive with this.
I am becoming a staunch admirer of your work, too the point I can’t get my mind off what will be my first build (second board, once I get a Raptor 2), which would involve the urban Carver kit. How is it holding up so far? In case the bearing-less spur gave way, with time, could it be replaceable?
Thanks for the inspiration, no matter what!
Sound is not bad IMO, not that super smooth as a belt but ok…
Wear is super low, i dont killed ONE … that means its strong as hell
Cant tell how long they last for sure… but i guess +1000km
This are the very first gears, changed them to many differnt versions of the Drive :
-Prototypes
-Deluxe Alu Drive
-Eco Drive - Stainless Steel
-Eco Drive - Alu (only for science)
-Eco Drive - Steel lightened ( only for science)
So they get mounted/dismounted often, something i would not recomend in general because everytime you will change the position slightly… this will make the gears louder IMO
Anyway the shape is still ok i think, always one new one next to old one for compare :
Not really.
This Stainless Steel lasercutted one is really good as it is i think, also its affordable…
In the beginning of this i had a batch from 5 Deluxe Drives with machined aluminium motormounts, wider clamping, little lighter… price was alot higher but sold quickly…
Maybe i do something like this again as Limited Edition …
