Lube. Closed case.
IMHOâŚunlikely, half the torque we get out of dual motor setups. If anything gear drives will take over belt drives.
Thatâs only cause heâs using one motor. Two could easily fit on his trucks.
Wish I had some good news to report but I only made it to the end of my block before running into some concerns, I brake pretty aggressively and I think I messed something up, possibly because there is a 3d printed gear and a metal one
This definitely will fit 2x 6374 motors and easily can fit larger motors too!
Could you rephrase?
10char
Wow⌠lol
you can fit two motors traditionally, so whatâs the difference? OK, you can maybe fit 2 larger motors but doesnât really seem worth the trouble to me.
I mean, Iâm all for innovation, but I think what WOULD make this attractive is if you could fit the motor front mount on the rear truck and rear mount on the front truck so you essentially have 4 wheel drive with 2 motors and 2 ESCâs, but unless thereâs a way to make the motors fit under the deck in a sideways stance (as they do now) then you lose a massive amount of wheel base that would normally be used for batteries and electronics.
I didnât say âIMHOâŚunlikelyâ just because I wanted to type, I actually thought about itâŚ
I was only half serious in case it does.
It looks like an elongated tit.
Iâd put one of them spirals on the top like they do on airplane engines.
Well that, some people donât like longer trucks but want to be able to run motors bigger than XX55 and this seems a viable way to do so.
Needs to be reconfigured to drive both wheels with one motor. That will be a game changer
I can see some crazy light shows with these in reverse mount.
If you put two in reverse then you could use it to wring out wet clothes.
For the motors we use I would hate to think the amount of work a single motor would have to do to do so.
But i was actually thinking of that today, do motors with two keyway shafts exist ? Like instead of dual motors just one long motor with two shafts on the end for pulleys to go on.
I would like to test this with an actual non 3d printed gear. I actually like the idea, and it would be very viable for larger motors.
I think the 3d printed gear was the only reason this one didnt work out.
Yes, look at aps motors I think the 80100 series
damn, that looks shreded
I thought the reason this wasnât done before was the cost of the gear in metal.
I believe he intends to use metal for the final design and went with the 3D print for the Prototype run to see how things were working
