Or could get them to do some of the motors with 27 turns and 100kv. I don’t know what the top speed was and never get around to recording but the 100 were fast. I liked them a lot. I shorted them and told neighbor evohyak he can have them and make a four wheeler if he rewinds them.
This is them. With omega100 on a pealed off lam. It’s not good enough and I’d dip it in something. Just a couple teeth wrapped in wire. Maybe hose the windings down with something since you’re not trained to wind.
I do have 4 200kv motors! If someone is thinking about breaking the speed record. Anyone? It’s just 60
Yes those batteries. My potted cells sit here not done and pretty much done but I haven’t gotten around to using it
This look s dope but why do u all keep using 18650s i would think 26650s would be better as fewer cells means less a chance of shorting out. Also prolonged life from charging as this means they have less of a chance of dropping out.
I’d think smaller cells would be nicer as long as you don’t have to think about disconnections. My rubber battery I’ll be thinking about it! Maybe smaller cells weigh a bit more for their energy but probably not much.
Sure evohyak when I finally get around to doing something with my other vescs other than duct tape or Velcro. I have tubes of this stuff which looks good but I want clear for the lights
I’m regretting potting the batteries and wish I’d spent my time building the board. I still haven’t seen a good board that’s also a battery case. Simply a board with cut outs for 18650, and copper tabs or Springs or heat if need be. I’d like to see the board and batteries under me standing on them. An 18mm thick board. And then pot those cells in the minimum resin possible.
Hi guys, i´ve just arrived to e-skateboard world (I´ve experience in ebikes), and after reading a bunch of posts, i think I´m gonna try those motors @Hummie…
I´ve got my old skateboard (loaded tan tien) in the garage, so I´ll try to upgrade it with those motors (probably for my first build will be better if i try with just one motor, no?
I will use a 8000 mah 6s battery which i use in my ebikes, so what do you think guys, is it a crazy idea? or it´s better start with pulleys, belts and so on?
thanks @monkey32… Almost all posts that i read about hummies motors are positives… so i think is worth it try them
Actually I´ve a couple of 8000 mah 6s, but i think 12s 8amp for my first build is gonna be insane hahaha
@Hummie definitely i will go for a couple of motors, let me know how i can do it…
The thread is long but if u get some of the aluminum I’ll give you them for 200$ plus shipping wherever.
…and u can get the pressed steel and magnets that do 300f for 225 later of u want
Just PayPal me humminashadeeba@gmail and it won’t be long…just waiting for the good rubber to come
Hi there,
a couple of doubts… will i have any issue with my trucks paris v2 180mm or i need to change them? and my wheels right now are 70mm ( i think) so should i change all of them?
I will go for the aluminum ones and i live in Ireland, so what would be the shipping cost?
The motors will lengthen the axle by 15mm so if u get one 165 and one 180 Arsenal cast trucks it’s easiest. The Arsenal don’t need any further threading and are easy.
The rubber matches the kegel wheel shape, I’d get them
I use the Paris v2. One 180 and one 195 and I like how wide they are. But they do need to be slightly further threaded. If u want to give me the cost of a truck and the cost of two wheels and 20$ I can get them further threaded and mounted. Or you can do it yourself.
Shipping is expensive at 50$ but I have a family member coming from Ireland and I bet I could get him to bring the package back. Complicate things but could save you bucks. You’ll need to wait maybe a week anyway while I wait for the rubber and pour it
Good stuff!!
if your family member bring the package back will be great! then i will pay the cost from his/her home to my home, unless he/she lives in Wexford or close …
Ok so, I will pay you for one truck + two wheels + 20$ + 200$ + shipping cost to ship inside Ireland if he/she doesn´t live close to Wexford( if you tell me the city and size, weight of the package, i could see the quote on internet and include everything), what do you think?
And don´t worry I can wait for one or two weeks)…
Give me the final quote, and I will send the money through paypal, is it fine?? i
I feel like I’m going to go with carvons, but I have a few questions.
I’m building a tiny board, 30 in, and range is a big factor. With a carvon single I can get 15-20 miles range and 25-30 mph with the amount of battery that I can fit on the board. If I were to go with your hubs, wouldn’t I really need to go with duals to get what I want, and wouldn’t that lower my range. Plus, another vesc isn’t what my budget needs.
Looks cool
Cheap really
Option of getting the steel later!!
You’d need two motors and that could lower your range a bit…but then if you’re using a single 140kv or whatever they are now…it takes a lot of amps to get torque and who knows.
Like I said before, I can’t imagine the carvon single having the power you want. 2 motors will always be better than 1. It’s more money as you need another esc, but there’s a huge increase in performance. These guys have more torque than the carvons, due to the lower kv, but the carvons single might get 3 or 4 mph faster. TBH, at those speeds, 1 motor when breaking is scary. Using one motor makes the board want to turn real quick on brake/acceleration. If you don’t make the correct weight shifting adjustments, it will throw you off, which has happened to me before. I thought it was bad at 18 mph, I can’t imagine single drive braking at higher speeds.
